Loaders that fit MF 2135
hanke777
Which loaders fit a 2135. I see 100 & 200 but I don't see any in my area for sale. Will MF 32, MF 34 or ??? fit?
(quoted from post at 12:47:37 08/05/21) Which loaders fit a 2135. I see 100 & 200 but I don't see any in my area for sale. Will MF 32, MF 34 or ??? fit?
Parts book for the 32 shows there were mounting parts for the 2135. The thing you are going to run into is the mounts for a given loader may be different for different tractors. So unless it comes off a 2135 and you get all the mount Kit with it, you may have to modify or build mounts. Many loaders will fit, if you want and can modify mounting parts. Do you have the capabilities to build mounts or have them fabricated or are you looking for and limited to one that will just bolt on with no modifications?
I would prefer one that bolts on without to much fabrication but with pictures I could probably fabricate mounts. I saw a MF 102 loader off a MF 220 tractor for sale but not sure if that is a good option. I wold like the loader to have pressure up & down.
(quoted from post at 09:15:11 08/06/21) I would prefer one that bolts on without to much fabrication but with pictures I could probably fabricate mounts. I saw a MF 102 loader off a MF 220 tractor for sale but not sure if that is a good option. I wold like the loader to have pressure up & down.
Use the on line AGCO parts books to look up a loader you think will fit and see what mounts were available for different tractors. That will tell you if others used the same mounts you need for your 2135.
https://apb.agcocorp.com/
