Good day! First post - I have learned a lot reading the last few months and finally joined!
I have an issue with a new to me MF20 (maybe 20C?) Backstory - bought from 2nd owner, 3 pt. lift never worked for him and he thought the pump was bad. I got into it and there is almost no lift components under the lift cover (no lift cylinder, vertical bracket or associated components). I guess something went wrong and he just pulled it all out. I pulled off the small cover at the top of the standpipe and the hydraulic pump shoots out fluid just fine, so I think the pump is okay. So, I am hunting down a new lift cover and components.
I am almost certain the tractor is a 20 and not a 20C. Serial number is 9A231626, and decals all have MF20 and not 20C. From looking at the parts books, I also notice the 20C appeared to have a metal slat front grill, whereas mine has a metal mesh front grill (with the "ridges" pressed into it). Are there any other telltale signs to distinguish between the variations?
Next question - Looking at the parts list, it looks like a lot of the part numbers between the 135 and 20 are very similar for the lift cover and lift components (gasket, vertical bracket, cylinders, some levers). Casting numbers are a different story and the numbers I have seem to not match even the parts book references, so I've stopped looking at those. 20C has different lift components.
My second question is, I have a lift cover and the components from a 135 available, and I can simply swap out lift covers. I've read from previous posts that the 20 and 135 are very similar. Has anyone had any success/experience with doing this? The footprints match and the vertical brackets (supporting the levers and response dashpot) are the same part number, so I'm hoping it will work in an MF20.
Thank you in advance!
