MF135 clutch pedal
Ironmk
New User
I have a Massey Ferguson 135 and was looking to make the clutch easier to push. The setup now is a pedal straight to the clutch shaft on the transmission. My brother has a MF150 and he has a pedal going back to the PTO lever housing to a mount and then to a rod going up to a lever on top of the clutch shaft going into the transmission, giving you a mechanical advantage. Has anyone tried or better yet succeeded in put that set up on a 135 to get the mechanical advantage to make the 135 easier to push the clutch?
Why not just fabricate it and try it? I've built several linkages like you are describing and the worst you can do is get the leverage points wrong. Just be sure nothing binds up in the geometry, or use small Heim-type ends (easily found on junk snowmobile steering linkages. You might have to cut and weld more than once, but what's the fun in getting it right the first time. steve
(quoted from post at 20:51:34 08/01/21) Why not just fabricate it and try it? I've built several linkages like you are describing and the worst you can do is get the leverage points wrong. Just be sure nothing binds up in the geometry, or use small Heim-type ends (easily found on junk snowmobile steering linkages. You might have to cut and weld more than once, but what's the fun in getting it right the first time. steve
I have the technology and skill I just thought having something to start with would help. I have 2 different options to consider and one would depend on if I could put power steering on the right side of the tractor instead of the left to eliminate the left pitman.
