Work Bull 303 steering box
Getting ready to tear down the steering box on my 303. When you turn the steering wheel the shaft turns about 3 times before it engages the tires. I am thinking its the worm gear inside the box. Anyone have experience opening these up, and or finding parts? I appreciate the help.
(quoted from post at 08:40:18 05/07/21) Getting ready to tear down the steering box on my 303. When you turn the steering wheel the shaft turns about 3 times before it engages the tires. I am thinking its the worm gear inside the box. Anyone have experience opening these up, and or finding parts? I appreciate the help.
Read this start to finish first, I started this thread last year and some of the guys in there were super helpful.
I've now got hardly any play in mine. Make sure you read every post.
https://forums.yesterdaystractors.com/viewtopic.php?t=1437117&start=0
Read the entire post and was most interested in the post about if nut was to tight would cause the power ateering to not work. Have a 135 gas that I just purchased with rising steering wheel problem but plan
to just use motor in my 204.
(quoted from post at 06:22:01 05/07/21)
Thanks. Will look at that...sounds just like my issue. P.s. works well no leaks....
