3 point hitch issues
Rantalocy
New User
3 point hitch arms will lift but the arms dont go up till the lever is moved the last inch. Then they come up fast. No small adjustments. Also shutters sometimes.
Oil is new,no sign of water when old oil was drained.
MF uses two levers to control the three point. The outer lever is the Draft it is used for ground engaging equipment, plow disk, cultivator etc It should function only when the lever is close to the two marks on the quadrant. It is NOT to be used for position control especially when hooking up or unhooking equipment. The inner lever is the position control lever, move the lever and the hitch should stop and move according to the placement of the lever. If the hitch does not function this way you have an issue with the internal linkage either it is damage or out of adjustment. Just to be clear this applies to the MF 40 industrial tractor. The Ferguson 40 (same as the MH & MF 50) is a different beast on these if the hitch does not respond to the inner lever again the linkage is damaged or needs adjusted
