Smitty BaCall
New User
Hope somebody can help me with this. I brought MF 135 with a hydraulic issue. I removed the lift cover and found cracked lift cylinder. However, I don't see the pressure control valve, Tube
(Connect the both) and the diaphragm. Only Control dashpot is there. What is the purpose of those 3? what will happen if I don't install the pressure control vale, Diaphragm and tube? Thank
you. (dashpot P/N is 898159 M2
My Tractor S/N 9A 112985 MF 135 Diesel with a Fwd & Reverse Shuttle control (Hand controller to use with clutch)
I can provide more information and picture if needed.
