Greetings! New here. I recently bought a non-running MF65 with a Perkins diesel engine. Cleaned up the fuel system and got it running. It runs well, has 40+ lbs of oil pressure. So, I warmed it up and proceeded to do an oil change. There was a slight bit of water in the oil...probably from me pressure washing it on the way home while it was still on the trailer. I drained the oil, then removed the sump screen. After the sump screen came off I found three separate pieces of wadded up steel in the sump . What in the world could these be? I looked up into the crankcase at the rods and oil pump...they don't seem beat up. I am hoping someone here can tell me what these are. I have pictures and will post if i need to but i dont think they will tell you much more than i have described. Thanks ahead of time. :shock:
