1964 mf 65 power steering cylinder.
tgrist
I need to seal up my power steering cylinder. sn 706---. I saw a post from quite a while back that had several pictures and they are no longer visible. Does anyone still have those pictures? as well as, What is the operating procedure? Which kit do I need to buy? does it need to include hydraulic piston rings? Thanks all, in advance.
Where is it leaking? If it is the small shaft on the top it is just a simple o=ring replacement. Fixed mine a couple years ago.
(quoted from post at 08:17:58 03/07/21) Where is it leaking? If it is the small shaft on the top it is just a simple o=ring replacement. Fixed mine a couple years ago.
I think it is just leaking around the main shaft. but it is probably leaking there too.
The repair kit is part number 830860M92
Your power steering cylinder should look like this.
yep that's it. I just ordered a seal kit. Thanks very much to everyone who posted. and now I wish I had a diagram. the manual I have is almost useless.
