Found a Massey 165 for sale with MF32 loader
LDPosse
I found a Massey 165 for sale with MF32 loader. Is anyone familiar with this setup, and how difficult it is to take the loader on and off?
Also would it be hard to add a quick attach plate to one of these?
Thanks!
It's not meant to be taken on and off regularly and easily like the new ones you're probably thinking about. It's doable, but
requires supporting it, removing two bolts, 2 cylinder pins and disconnecting and plugging the 3? lines that run up the
inside of the right loader frame from the control valve. Then you'll still have the frame mounted.
I have an MF35 with loader (unknown brand) The loader has a frame bolted to the tractor with the loader itself attached to
this frame by four bolts, two to hinge on the frame and two to the pistons. I built a structure like a large door frame out
of rough cut 2x8 lumber with triangular OSB at the corners for support. The structure is wide enough to drive in the tractor
and lift off the loader with a come-along. I can then lower the loader to the ground and available the next time I need it
which is only occasionally. The frame part of the loader remains permanently bolted to the tractor.
