Good day all. I just purchased a 1974 / 1975 MF 135 with perkins 3cy gas engine. Im not sure what model or year it is because the tag on the dash was destroyed. Issue im having is the oil pressure on start up goes all the way high in the red and then after about 30/40 mins I will run it and if I put the throttle back to idle speed it will jump down to the green area. Is this normal? the seller used 15w 40 rotella in it. And also see attached pictures. There is a plug close to the oil pressure line that looks like it was cut off or something I have no idea what that plug is for. Any help on this would be appreciated from the high and wise lol
