Used hydralic lift pump needed.
ptfarmer
Location
San Antonio, Tx
Does anyone have a old, used, hydraulic lift pump like from a 135, or something laying around that they would like to git rid of? I need one for a project, the pump doesn't need to be functional, but I do need it so I can still use a pto shaft out back. I'll pay some for the pump, and the shipping. Thanks!
I have one, it has pitting on some parts.
The shaft may be good think it is some what
apart. I would sell it. It is heavy. Not
sure what it would cost to ship. Was a 10
spline from 20 but should be the same as a
135.
I may have one from a MF65 I won't be able to get to it until spring. Let me know if you don't find one before that. It don't work as a pump but would work for a PTO.Not sure if the drive is the same for a 135 as the hydraulic control is different. It will be cheap if you can use it.
(quoted from post at 15:58:10 02/18/21) I have one, it has pitting on some parts.
135.
The 20 is pretty much a 135 so it would work.
(quoted from post at 16:00:15 02/18/21) I may have one from a MF65 I won't be able to get to it until spring. Let me know if you don't find one before that. It don't work as a pump but would work for a PTO.Not sure if the drive is the same for a 135 as the hydraulic control is different. It will be cheap if you can use it.
I'm not going to use the control from the pump anyways, but the 65 pump is the same (10 spline). It's for my MF2135 with the manual shuttle shift. Going to make my version of a MF tractor shovel. With this snow going on here around San Antonio I've been looking at getting this project going again.
I have a complete valve chamber as I ordered a new 1 for my 135. Looked as if it suffered a freeze that buckled top of cyl. chamber that you can have.
