Dieseltech
- Location
- Akron, Indiana
I'd check the supply pump FIRST before messing around with the tanks. Question, with engine running does fuel shoot out the injection pump TOP COVER bleed screw? If not,
filters MAY need changed or supply pump is NOT working right. I've seen one of the two supply pump check valves fail, and when that happens engine WILL shut down for no
apparent reason. The constant bleed orifice on the filter base MIGHT be plugged too, and not letting trapped air out of the filter base as it should. If ANY air then
gets into injection pump engine WILL shut down.
