Donovan572
New User
This message is a reply to an archived post by Ray UK on June 24, 2014 at 11:07:58.
The original subject was "Re: Removing gas tank on 135".
I just went thru this with my 135. I found a solution for installing the tank that worked out great for me. I used different nuts on the bolts that hold the front of the gas tank down. The nuts I used are much longer than a regular nut. They are so long that when barely installed (only a few threads engaged) they hold the bolts up so the tank will slide on. Once the tank is on, the long nuts are much easier to find with your wrench for tightening. I used a ratcheting wrench to tighten with.
This my first post here. I'm going to try to post a link to the the nuts I used. I hope it works.
Untitled URL Link
Untitled URL Link
