Massey Harris & Massey Ferguson Tractors Discussion Forum |
MF50 rear axle compatibility
Author |
[Modern View] |
KyleNeron
01-10-2021 16:04:41
Forgive me if my terminology is a bit off as I am relatively new to tractors. I have a 1956 MF 50 that a have used hard and gave me no problems until yesterday. Long story short I am in need of a rear axle housing and top cover. Basically everything under the seat. The cast iron housing that bolts to the back of the transmission is cracked beyond repair. What models can I use parts from? What years should I look for? Is there anything I need to be aware of when looking for a parts tractor to repair mine? Thank you for your help.
miner09
01-11-2021 07:22:51
Re: MF50 rear axle compatibility in reply to KyleNeron, 01-10-2021 16:04:41
If it's a 56 model then it's not a MF. A MH50 or Ferguson 40. May have wrong decals which has happens often. Look at serial tag. The early MF50 (58-59-60) will work but the later may be some difference. Be sure and check before buying.
54FergieTO30
01-11-2021 04:40:34
Pretty sure TO35, MF35, F40, and MF50 all used the same rear end.
54FergieTO30
01-11-2021 04:39:10
I believe 35's and 50's use the same rear end. Some 35's (those late in production run) had differential lock. Not sure if yours had diff lock. There are casting numbers on the rear end, just look to match the casting number. The axle housings could be moved over to your "new" rear end housing. Hydraulic pumps varied in 35's, so you will want to check to see if those match up.
KyleNeron
01-10-2021 20:04:18
Pump and relief valve were replaced less than 6 months ago and gave no problems. The housing was cracked and welded before I ever purchased the tractor and it seems to have just given up. Im not nearly as concerned with cause of failure as I am finding replacement parts.
Dieseltech
01-10-2021 18:19:29
Is the diff case and lift cover damaged do to a bad hydraulic pump relief valve?
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Talk of the Town: Trailerin a Tractor, Chains or Straps? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: " I bought a trailer and plan to take my CASE VAS to some shows. I don't yet have anything to secure it to the trailer. So which is better to buy and use; the ratchet-type straps or binders and binder chains?
... [Read Article]
Latest Ad:
Carburetors for sale Marvel Schebler models TSX 408 and a TSX 244 B both rebuilt. Asking 250.00 each Then I have a Carter UT 0-652 on base 0-653 24 on neck with 179380 on throttle shaft asking 50.00 for this one.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
