Massey Harris & Massey Ferguson Tractors Discussion Forum |
Massey 1135 no hydraulics
Author |
[Modern View] |
Kdmcg
01-07-2021 20:26:48
Last fall I was mowing with my Massey 1135. I stopped for a short break shutting the pto off and ideling at 900 rpm for about ten minutes. I climbed back in and flipped the pto lever it started and the stopped. No hydraulics.
The charge pump was removed and could not see any evidence of failure. It was then notice that the pto clutch pack would turn by hand. Then removed the pto clutch pack and shaft for inspection.
I put the shaft back in and could not turn it by hand. I put the shaft on the clutch pack and could not turn by hand. Then both the shaft and clutch pack were reinstalled and it felt secure with minimum play. An hour later I check it again and you could turn it by hand. Shaft and clutch were both turning. It was like the shaft was not going in far enough.
Thank you for your help
Dieseltech
01-08-2021 04:53:28
Re: Massey 1135 no hydraulics in reply to Kdmcg, 01-07-2021 20:26:48
The flywheel splines MAY have failed on the PTO input shaft, and there's also a rear coupler at other shaft end at the trans-diff split joint that can strip splines too. Loose EITHER one and ALL hydraulics will stop. I'd start with the engine clutch split and hope that end is bad as that shaft will pull out the front, and the front drive coupler replaced. If the rear one is bad too, the trans-diff split will need done also..
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Restoration Story: 1929 McCormick-Deering 10-20 - by Randal Simmon. On July 4th 1998 my dad and I was sitting on the front porch when he said that he was going to sell his two 10-20's to a junk man. He said that the junk man was going to give him $500 for both of them but he hadn't received the money for them yet. So I went into the house and wrote him a check for $500 and bought them myself and said now they are mine. He had bought them about five years before thinking that he was going to restore them himself. After five years sitting in the barn, he changed h
... [Read Article]
Latest Ad:
John Deere 50
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
