Massey Harris & Massey Ferguson Tractors Discussion Forum |
MF 65 Diesel breaking starters
Author |
[Modern View] |
Al King
01-05-2021 14:41:04
I have a MF 65 with an indirect injection 4 cylinder perkins. The back plate on the starter was broken when I got it. Replaced it and it broke again. Pulled the starter all apart and everything looks good. Could it be caused by the fuel injection pump timing being too far advanced. The tractor starts and runs well, it starts quickly with no effort. It does smoke quite a bit when it's cold, but I think that's normal. The timing marks all line up. I pulled the front cover and checked. I have never seen an engine push the end plate out of the back of the starter before. Any suggestions?
gbs
01-11-2021 17:49:43
Re: MF 65 Diesel breaking starters in reply to Al King, 01-05-2021 14:41:04
Does your starter have the 3 bushings? The reason I asked I had a 3 bushing Delco starter rebuilt on a 275 put it back on it would barely turn, pulled it back off hooked a set of jumper cables to it spun like a top, put it back on same problem, the battery was load tested to begin with, tried another known good battery with jumper cables no change, pulled it back off tore it down rebuilder had put carbon brushes in it in place of the metallic ones, too long of screws in the brush holders, dug a little deeper and the screws were left out off the center bushing plate because it came without the mounting holes bored, that is where the main problem was , when the starter was activated the magnetism of the fields would pull the bushing plate against the end of the armature shorting it out. If yours used the center bushing and it is damaged or missing your armature could be bent or flexing damaging the end plate. if the flywheel end play was causing the problem you should see where it is contacting the Bendix overrun clutch.
John Deere D
01-05-2021 14:45:10
Crankshaft Thrust.?????? Bob..
Al King
01-05-2021 15:42:46
Re: MF 65 Diesel breaking starters in reply to John Deere D, 01-05-2021 14:45:10
When I got this tractor it was running, but had a knock in the engine and low oil pressure. I tore it apart and found that the No 4 rod bearing was gone and had scored the crank. So I put a new crankshaft and bearings into it. I replaced the rod with the spun bearing with a new one. Also put in a new oil pump. By the way the rod bearing went because of someone using too much silicone gasket seal. A piece got into the oil gallery and blocked the flow to #4. So the crank end play is with in new specs. I also put in a new ring gear. I did not remove the injector pump to work on it. So the timing is as it was before. But it's anyone"s guess if the pump has been "adjusted".
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Talk of the Town: Trailerin a Tractor, Chains or Straps? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: " I bought a trailer and plan to take my CASE VAS to some shows. I don't yet have anything to secure it to the trailer. So which is better to buy and use; the ratchet-type straps or binders and binder chains?
... [Read Article]
Latest Ad:
Carburetors for sale Marvel Schebler models TSX 408 and a TSX 244 B both rebuilt. Asking 250.00 each Then I have a Carter UT 0-652 on base 0-653 24 on neck with 179380 on throttle shaft asking 50.00 for this one.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
