First thank you in advance for any advice. New tractor owner, and I'm learning as I go and this forum is a monumental help. I have a MF65 with G176 engine. Tractor has been sitting a long time and just getting to getting it running. I have an issue with the what seems like run away idle. Meaning if I leave the throttle alone in a single position the governor runs away with it and I have to hold the throttle steady to keep it even. I checked the linkage to the throttle and it is not loose. What should I check? Do I need to pull the governor off and replace some stuff? pretty sure I have a water pump that is leaking so I could do both at the same time since I assume I need access to the front of the engine. Sorry if my posts don't make sense, I'm learning as I go.
Thanks again in advance.
