Massey 35 diverter valve
Dano41
Hi,could anyone please post a pic or a diagram of the correct diverter valve and how it is piped to run a log splitter on a 35.
I guess it depends more on your diverter valve, here are some pictures I've collected over the years of different setups.
Hi, there isn’t really a right and wrong way. It’s really down to what is
available. My choice would be for Scoobie’s last photo where the
supply line to the splitter valve is 3/8” bore and the return line to the
oil filler cap is 1/2” bore. This avoids any possibility of back pressure.
As long as you have your supply line from the divertor going to the
inlet on the splitter valve block and the return from it going to the
tractor transmission case or return port on the div valve you will be
ok.
DavidP, South Wales
