My 1100 we cobbled together a few months ago now needs and engine overhaul. Long story short, after about 40 hours of run time on the engine, it tried its hardest to seize up.
I had what I thought was a good recently rebuilt motor that just needed a new set of bearings due to diesel in the crankcase. That wasn't the case as water had somehow gotten in it and ruined it.
Now I'm not sure which way to go. I had plans to vat, overhaul and paint the engine since it was out of the tractor. I want to paint the tractor, and the engine seemed the most complicated part. So I figured now was a good time to do it.
It seems that the engine that we had as a back up had low oil pressure at idle, even after being rebuilt. Are the oil pump and main bearings the major things that contribute to oil pressure? The machine shop we spoke with says it doesn't use cam bearings. I don't want to rebuild this thing without correcting that. The engine in the tractor had great oil pressure even as it failed, and part of me thinks I should just rebuild it. The crank in the back up motor is too worn at the thrust washer and will have to be repaired for use, I'm unsure of the condition of the crank in the tractor as we haven't torn it down yet. I can get one that's been turned 10/10 and is ready to install for $450.
I guess I said all that to say this. What steps do I need to take to correct the low oil pressure? Or would it be easier to in frame the engine in it and deal with painting it in frame as well?
