Dirtrancher
Greetings, I have a MF 3165 with the MF hydraulic system. I tried to use the hydraulic system for the first time, but nothing happened when I moved the controls. Neither the position control lever nor the draft control lever resulted in any movement. I have no idea if I'm doing something wrong or if the equipment isn't working properly.
Is there more to it than simply moving the control levers?
What would be the best approach for troubleshooting?
The quadrant support piece is broken, but the inner and outer shafts still seem to move properly. I took the quadrant off to get a closer look. (See picture)
Thank you for your help!
