loota
HAVE A MASSEY 22 REAR RIMS ARE STUCK ON TRYED A LITTLE prey on the notch on the hub, HIT REAR OF RimS WITH SLEUGE HAMMER USED LIQ. blaster no luck .
never had trouble like this befor with other tractors-----help
you bet ya! took me 4 hrs to get one of my oliver 88 and less than 2 hrs for the other side. you need an air chizel and a big sledge hammer and lube and keep working at it the leaking calcium was just like welding them to the hub. both rims were junk. on this oliver it only had about 1/16 clearance around hub and rim and it was seized right around.
(quoted from post at 12:06:47 09/24/20) HAVE A MASSEY 22 REAR RIMS ARE STUCK ON TRYED A LITTLE prey on the notch on the hub, HIT REAR OF RimS WITH SLEUGE HAMMER USED LIQ. blaster no luck .
Try spraying a bit of Kroil in there. You can heat the face of the rim, but be careful not to put too much heat on it. You can use a come-along against a tree (with the lugnuts on finger tight so you don't drop the tractor on the ground)
You can use a hi-lift jack against the other wheel, just not too much pressure so you don't bend anything. Throw some heat at it with the pressure and it'll pop eventually.
Bead Breaker..
Check out ..
DIY Tire Bead Breaker on U-TUBE
On the internet ..
Type in bead breaker Yesterdays Tractors...
Bob...No reason for manual Labour........:)
