1080 PTO not working
I do not know as we unhooked the auger and put a 180 on it. If I can figure it out, I will post. Thanks!!
If the hydraulics aren't working either, it is likely to be a problem where the outer transmission input shaft splines into the hub on the back of the clutch cover.
