Company Logo Shop Now
MF 35 hydraulics
James1690
09-15-2020 03:29:11
Hi guys
Changed hydraulic pump and hydraulic lift cylinder on my 35 all worked good until I moved draft control lever then it brake the mounting bolts off anything I can check or set properly before I reassemble nothing else appears to be damaged think all levers were in tight place between hand control and pump
Cheers
DavidP, South Wales
09-15-2020 12:26:03
 Re: MF 35 hydraulics in reply to James1690, 09-15-2020 03:29:11
Hi, when changing components in the hydraulic system in particular nothing can be assumed to be correct until it has been adjusted. Are you referring to the four 13/16" spanner size bolts in the centre of the hydraulic cover or the ones that hold it down on the centre housing?
DavidP, South Wales
Dieseltech
09-15-2020 08:11:12
Did you replace the pump safety relief valve? If it's stuck closed or set too high that can break parts..
John Deere D
09-15-2020 08:00:40
What exactly failed??... Pics off internet....
Copyright © 1997-2020 Yesterday's Tractor Co.
