MF 35 hydraulics
James1690
New User
Hi guys
Changed hydraulic pump and hydraulic lift cylinder on my 35 all worked good until I moved draft control lever then it brake the mounting bolts off anything I can check or set properly before I reassemble nothing else appears to be damaged think all levers were in tight place between hand control and pump
Cheers
