Well i had the hoe controls rebuilt locally finally for $350 no more leaks
Everytging works except one outrigger/stabilizer
We have tried heat,soak,sledge to no avail
Pull the foot pin and cylinder will come out fast amd lift the tractor
But that sleeve is stuck solid
Think i can cut up the tube facing the tire where it was factory welded top to bottom to allow a lil clearance and then plate it and weld it up ?
Any other suggestions
I adjusted the seated spring above the selector valve maybe a relief valve and everything seemed to work faster and better on hoe controls it was screwed all the way in and i backed it off 3 turns
