I have a 1963 MF35 gasser. This morning, I was going to use my bush hog and cut my power line. The engine speed PTO would not engage. I tried several times, engaging, disengaging the clutch and PTO with no change. I tried going from enginee to ground and back. turned the tractor off, back on and still no engine speed PTO. The ground speed PTO does work as normal. the last time I used the engine speed PTO it worked fine. I am not aware of any changes that might cause this.
anyone have any ideas where to start?
Thank you
Vann
Thank you
Vann
