doublebass73
I looked at a 135 for sale yesterday. Had a nice running Perkins diesel, very good rubber all the way around, 8 speed tranny that worked good but tractor also needed a bunch of electrical work and had an axle seal leaking on one side. It had a couple issues I was unfamiliar with so I walked away from it, I was wondering if the more experienced here could shed some light on them:
1. 3 point lift was jerky on the way up whether it had a load or no load. It seemed to work ok other than that. Fluid was at correct level.
2. The two stage clutch would not disengage the PTO when I pushed it all the way to the floor, I had to grind it to engage the PTO as well. Is that an adjustment issue or a bad clutch?
