I have a MF 135 with a Perkins 3cyl gas engine (AG3.152). It started running rough. I rebuilt the carb, replaced filters, sediment bowl and gas lines, and cleaned the tank. Compression testing was 85, 99, and 100 PSI on 1, 2, and 3 cylinders respectively. Still ran rough, and eventually became harder and harder to start until now not starting. I finally checked for spark and there was none.
I get spark from the coil, but nothing out the distributor cap. I've replaced the condenser, points, rotor, coil, and distributor cap 3 times and plug wires and ignition twice. I've moved the dwell 180 degrees in both directions to try and get a spark with no results. I've also swapped the distributor with no results.
Does anyone have any ideas of what to try next?
Thanks
Thanks
