Massey Ferguson 85 remote valve
craigsme2
New User
Can someone help explain how it works. I've hooked up a 3 pt backhoe but I'm not familiar with the remote controller. I have two levers in front, one valve on the side. Two small knobs and a bigger knob in the rear. Tractor is a 1962 and I have no manual and can't make the backhoe work. Maybe someone can help educate me?????
If it works like a 65. Place the left of the two levers in front in the center position(valves mounted in front of the seat on trans-case). Place the right lever in the forward position (this lever may require placement in the rearward position depending on connections), place three point lift control all the way up in the constant pumping position(on 65 has a silver nob). This should get oil going to remote valves(follow the lines). If it came with a factory backhoe and has a front mounted pump forget the directions above. Look for a knob on a valve you came pullout.
(quoted from post at 05:54:08 08/21/20) If it works like a 65. Place the left of the two levers in front in the center position(valves mounted in front of the seat on trans-case). Place the right lever in the forward position (this lever may require placement in the rearward position depending on connections), place three point lift control all the way up in the constant pumping position(on 65 has a silver nob). This should get oil going to remote valves(follow the lines). If it came with a factory backhoe and has a front mounted pump forget the directions above. Look for a knob on a valve you came pullout.
Ok I'll give it a try, any idea on the backside 3 knobs do you have any idea what they control? 2 smaller knobs and a big knob?
