MF 65 with 190 Perkins
4020_guy
Was given a 1960-61 high arch 65 with the indirect injection 190 engine. Power steering, 6 speed, stored inside, rolls over by hand, 2 stage clutch, and all there. Any thoughts or advice? Is there much difference in the 2 engines?.....Ron
Dieseltech, tractor ran and was parked there to repair the final drive, probably 10 years ago. Farm was sold so I got the tractor on 3 wheels. It has a CAV pump I think. Could any thing seize in there? Thanks......Ron
Yup, sitting that long I'd be surprised if the engine will run. I repair several pumps each month with stuck plungers and valves from setting with stale fuel.
Not start as in plungers gummed up or not start as in pooched pump? It is a CAV pump. Up here problem is most shops charge minimum a grand no matter what is wrong. Thanks again for information......Ron
