I have had starting problems that seem to be getting worse since I bought the tractor. I have average mechanical ability, but certainly not a mechanic. My biggest problem is the it is intermittent, and cannot consistently tell what the problem is. I replaced the ignition switch. No difference. Last summer, I took the starter to a shop that "bench tested" it and said it appeared to be good, but could be "going out." I have considered that it is a safety lockout issue but don't understand why i can't straight jump the started from the battery. I usually don't get a click of the solenoid. I have take the starter off multiple times, clean contacts multiple time. Sometimes that works and sometimes not. The only thing that is consistent is that when I turn key to "accessory" the two lights in the picture light up and immediately go out when turned to start. Any advice appreciated.
