Identifying year of MF 135
lstra
I bought a used MF 135 several years ago. It is an early one, had a generator, no id plate like my newer 135. Doesn't have holes in cowl like ever had one. My newer 135 has a metal plate attached with screws. Did the earlier tractors just have a decal? The number on engine behind injector pump that is cast on engine is K 11 4. Below that is this # which looks like a block casting number 37111450. Would by chance K 11 4 be Nov,11, 1964? Think 135 were 1965-1975. Thanks for any help on this.
Check at the front of the oil pan near the drain plug for the cast date. That is when your tractor's engine was born.
Remove the complete air filter assembly and you will be able to see it. Mine is a 1964.
