I have an MF 35 Utility with a z134 continental. I’m going to drop the oil pan because the previous owner was not up to date on oil changes and I am pretty sure there is 15 lbs of sludge hiding in the pan. I am planning on placing a jack under the bell housing and jacking it up until the the front tires come off, then lower it so that they are supporting just a little bit of weight. I’m concerned about warping or cracking the block since the oil pan is a structural member of the tractor. Any advice is greatly appreciated.
PS: it has a front loader if that makes a difference.
