http://www.tractordata.com/farm-tractors/000/8/5/855-massey-ferguson-2640.html
110 hp 6 cylinder Perkins according to tractordata.com
2640 is a French built tractor that was built at same time than the 2705 Tractors built in Detroit. The design looks the same, but the transmission is different. The 2640 is a solid reliable good tractor.
Ut has a mechanical shuttle reverser and a two speed,so they could make good loader tractor. The hydraulic is high pressure low flow, so you will not have as much capacity with a loader. If you have an mfwd, it is a good one.
neighbour is using and abusing one every day feeding cows, and no issues....
