John M Seasly
I need a source for for hardware to mount alternator on MF50 gas. The hardware that I purchased from this site does not work. I would sure
appreciate pictures of hardware that does work. The bracket that attaches to water pump bolt needs to be slotted in order to avoid taking
the water pump fan blade off.And longer with several bends in order to align. The other problem to the alternator has to extend past the
body in order to align the pulleys. All the help will be appreciated as I have fought with the new hardware for 3 hours and ended up
putting the previous owners bad alternator back on that was over 1" out of alignment in order to mow. But it will be eating that belt in a
short time.Thank you
