MF 202 with 102 loader and 185 backhoe. Loader and backhoe hydraulics are run from pump on front of tractor (driven by crankshaft).
I was using my loader in the morning without any problems. After lunch, I started to use the backhoe. After about 4 -5 scoops, the hydraulics quit. Now I get no movement with the loader or the backhoe. Hydraulic fluid level is OK and looks OK. I pulled off the pump and it does turn by hand. Also the crankshaft extender that drives the pump is turning. I don't see any external leaks or issues with the suction side (no collapsed hose). I have a pressure guage, but need to get some fittings to connect it. Does anyone have any ideas for further troubleshooting?
