Cormiers Cove
I have a brand new CAV TW50E 800/8/1800 that is for D3.152 perkins.
Can I use it in place of my MF 35X A3.152 CAV LW58 600/2/2390 if I change the governor spring and throttle locations and adjust the throttle lever to match the maximum no load RPM. Both pumps are timed for 22 degrees BTDC.
How does my old one with 58 cubic centimeters of fuel for 1000 squirts at 600 rpm compare to the brand new pump with 50 at 800 rpm?. Do these numbers matter if the governor spring and throttle are matched to the old pump and the throttle adjusted to max 2390 rpm no load??
