Phil Tibbetts
Drove over 250 miles today to look at a MF65 tractor that supposedly had 4 new tires. remotes, power steering, gas engine. The tires were
very good trea but far from new. Fronts were heavily weather cracked, rears were not too bad. power steering would work to the right but not
far to the left. Switch had been replaced with a push pull type similar to the old Farmalls. Push button switch for the starter which worked
sometimes. Remote bypass valve was frozen solid so the 3PH won't work, water definitely in the hydraulic oil. They said it had low hours,
which I doubt because of the overall condition and the fact that the hour meter said 800= hours but did't work. Needless to say I was POed.
why does anyone advertise something knowing it is a total falsehood?
