bkmathis281
New User
I have a MF135 with a Perkins diesel. When cold it will start and run fine. Cranks as soon as you turn the key. Then.... After running for 30 minutes or more if you turn off the tractor it will turn over but not start.
If you leave it sitting and it cools down for several hours it will start right back up no problem. I have resorted the just leaving it running if I need to do something.
I recently changed the fuel filters and the battery (not sure if it has much to do with the problem).
Any help/advice would be greatly appreciated.
