TO30 contradictory directions for brake shoe adjustment?
Charlie
I know this should be very simple, but something I did appears not right. The owner's manual (p35) says that to tighten the brakes you put the screwdriver onto the star wheel adjuster and push the handle toward the axle. The shop manual (p146) says that you turn the star wheel counterclockwise as viewed from above. For the left side of the tractor, I believe these directions are contradictory (For the right side they are consistent.) Can anyone clear this up for me? I need to get this adjustment right before any linkage adjustments. Thanks for advice.
