MF-65 power adjust rims
I need to adjust the back rims on my MF65. They are power adjust
they where very tight to loosen the 1 1/4 nuts and now I need to know if there is a torque to set them.
Unless the clamps were rusted and frozen, there was no need to loosen any nuts. The clamp is a cam-lock type which is designed that way for speed of adjustment.
If you are tightening the cam-lock units to the rim just use good judgement. No need for a perfectly even torque value.
Excerpt from the MF 165 ops manual. I would assume that the 65 is similar.
