33 Questions
Been looking for a 33 or 44 for years now, and found one at our local auction yard. Serial is 10147, which appears to make it the last year of production. Its in great shape, sheet metal all straight, good rear tires, no rust on the rims. It has dual rear hydraulic outlets. It has a big lever by the brake pedals - is that a Live power clutch? And there is a big line from the pump that looks to go to the steering box behind the front grille - does it have power steering? And I assume it could handle 3 pt hitch if I could find the parts?
I did not dare try to start it up, so I could not check it out further. But will try to go back tomorrow - the auction is Friday.
Thanks!
Tim
long leaver is for live power if it works .oil tank for hyd. is in front of rad. that line is supply for hyd.
You will need to find a parts tractor to get a 3 pth....the platform under the seat is much heavier, lines control valve cylinder etc., but it is not difficult to swap.
Ben
