Massy D-EO 20 rake
gjohnson
New User
Just bought a massey deo20 side delivery
rake and it needs a few teeth. Anyone know
where I can find them or if a new rake
tooth item number is interchangeable.
Thanks
I bought a few last year at Tractor Supply Co. for my DEO 20 rake. Some TSC stores have Masse rake teeth. Take one off of your rake it and bring it with you to TSC or other tractor store that sells Massey rake teeth and match to verify.
When I search that item number I can not
find any rake teeth match those numbers or
say they were replaced by something else
If you measure one of your old teeth, tooth coil measures 1.937", and the tine length is 7.25" (from the bottom of the coil to the end) you can use MF part number 667530M1.
I bought some from Sloan Express there are @ different ones the one my rake has a bend at the bolt end .When I bought them thay were around $1.70 each # 600364 there phone #1-800-934-9777 web sight www.sloanex.com this tooth replaces 667530m0or 668364m1 Massey Ferguson .Forgot to teuu you Sloan is in Assumption Il. 62510 Thay do ship.Good luck hope this will help you
