Re: Special wrench needed for MF135 injectors?
Masseynut(Australia)
05-31-2020 04:14:14
Hi Bill, If you are satisfied that you have bled the air out of the injection pump body via the two bleed screws, the air to the injector pipes can be bled by releasing just one of the three injector pipes at the injector pump head. It is not necessary to bleed the air at the injector itself. Once the injector pipe nut is slackened, pull the hand throttle to around half and crank the engine. The engine should start to fire on the remaining two cylinders. Then tighten the slackened pipe nut. Hope this helps, Evan.
