Farmer Rock
hey guys,some of you may remember a while back I posted about removing the backhoe off my mf203,we finally got that done thanks to your guy's help,so now we are trying to get the 3pt in order,but for some reason the lift arms will not lift or lower,i have messed with all the levers,and it seems the draft lever is not really doing anything but bouncing back and forth,and the arms pivot up and down freely by hand like it wasn't even connected to anything internal.if I understand draft control correctly,this could possibly be causing the problems by a broken linkage inside the lift cover?i appreciate any input and help.thanks
Rock
Rock
