MF in Canada
Hello folks,
I am thinking about buying a 1965 MF 135 diesel from a friend. Deciding on the price is tricky because the tractor has two problems which need to be fixed and we don't know what that will cost.
I'd like advice and experience on what these problems mean and what their repairs might be.
Problem 1: If we shut off the tractor after it has run 5 minutes or more, it won't start again until it has cooled down entirely. It turns over, but won't catch. Last time we ran the battery down trying, then put jumper cables on it from a bigger tractor and eventually, very reluctantly, it caught and ran.
Problem 2: Putting the clutch pedal all the way down does not stop the PTO. The clutch pedal works for shifting gears, but not for the PTO.
Would you be kind enough to share your thoughts on these problems and their repairs?
Thanks much,
Eric
ps. a third topic is that there is only one remote - a single outlet. I'd like to have a set of remotes so I could use my 3 pt hitch wood splitter on the tractor. Can anyone direct me easily to a thread about this subject?
Thanks much,
Eric
