What is this part?
Rkh
My mf65 gas has a leak around the round part next to the steering housing. What is this part & can it be replaced?
Hi, that item looks very much like the safety start switch if it’s on the right in front of the steering box. There should be two wires coming out of it, on to the solenoid and one to the key switch to ensure that you cannot start the tractor in gear. If there are no wires present it’s likely that you will be able to start the tractor in gear.....not good! Are you sure that the leak is from this switch? It’s more likely that it’s coming from the steering box to gear box gasket because the front bolts are loose.
David P, South Wales
If it's a breather vent, could it be leaking oil? If it's the safety switch,so It will move with clutch not engaged when starting.
