Loose clutch spline workbull 202
Posting again with picture and video don?t know if the play is normal
[video play=false:654c4848f0]https://www.yesterdaystractors.com/cvvideos/cvvideo5159.mov[/video:654c4848f0]
I'd replace those 2 bearings, Part number 195505M1 (they are number 7, and 9 in the picture, they use the same part number bearing). I'd also replace the seal, Part number 195523M1 (1-1/4"id x 2-1/4"od x 1/4") number 13 in the picture.
I figured I had to replace bearings and seals , I can see past
the shaft into trans and there was seepage of hydraulic fluid
,is this a difficult job I don?t have a press.This picture isn?t in
my book how can I get this pic with names of parts?i still have
to replace the hydraulic pump found it in pieces inside , this is
definitely turning into a money pit but I did get it for free.thank
you for all your help!
I looked up part numbers but they don?t say they are for 202 ,
I guess I should remove them and measure them out, side of
the trans says made in Mexico , had no idea they were made
there ,does that mean part would be harder to get for this.
(quoted from post at 08:54:15 05/19/20) I looked up part numbers but they don?t say they are for 202 ,
You can use the AGCO on line parts books at https://apb.agcocorp.com/.
When you get to the search page, put 202 in the search box, check the box for exact match and check the Massey Ferguson box in the manufacturers drop down list and search. You should see the book to chose.
Can?t get this site to work for me, entered my make and model
in search but won?t work.thank you for info I?ll keep trying
Are you using Google or Firefox, they seem to work best. Enter the site using "View Books". Type in just 202 in the search box, not Massey Ferguson 202, MF 202, etc. (I am working on a computer, not a phone so I'm not sure how it works with a phone.)
After you type 202 in a drop down list should appear under a "Brand" heading. Check the Massey Ferguson box. Last go back up below the search box you typed 202 in and check the "Exact Match" box. You should get the parts book #651104 for the 202 / 203 / 204 / 205 tractors (and another for the 202 forklift).
The other thing you can do is enter the parts book number (651104) in the model search box and that alone should bring the parts book up for you to select.
Are there directions on removing this , the clutch pedal shaft
is blocking the bearing housing im afraid to remove something
I should not .i see set screws in the shaft wired together, I
defiantly don?t want to mess this up, thank you for the parts
diagram
I notice a cover under this spline housing that is leaking also
would you know that number,I did remove the clutch pedal
and throw out bearing,is there any way to install bearings and
seal without a press or should I go to have them pressed
in,thanks for the info I can?t work because of the virus want to
get this thing done
I got it apart,looks like I can replace # 9 bearing and#13 the
seal I cannot do # 7 it?s part of gear box seperate from this,I
see a #16 I do not know what that is it?s not in my spindle ,
could this be why it?s wobbling , all there is , a bearing and the
seal I?ll try to send a pic
I tried again to get on it says no image , I?m using google on
my phone. I entered 202 then Massey Ferguson,202 came up
and work bull fork lift but would not open the pics for some
reason . I hope I can get on it my repair manual won?t show
me any part numbers just lists what they are,I have no
Massey dealer by me , thank you for helping me out.
(quoted from post at 21:44:21 05/20/20) I tried again to get on it says no image , I?m using google on
I have had it come up with no pictures on the computer but have managed to get it reset. No idea of how it works on a phone. If there is a bar at the below the list does it have a icon of a person near center and a square with the four corners high lighted near the right side? If so click on the square, it is supposed to reset the screen and will make some changes, at least on the computer. It may not be fully functional on a phone, I can't say on that.
I got on Agco site , I see part numbers but no pictures ,is
there a way to find out what transmission is mine.I know I
have a single clutch but need a picture to match part , I?m an
idiot in front of a computer
I got in , figured it out that site is great found everything
printed out a book , thank you much for this info,awsome!
I notice a timing mark on the spindle gear , does this have to
be splined with another Mark ,I did not think there is timing on
this
