65 multi power
haefs
How hard is it to rebuild the multi power on a Massey Ferguson 65 dieselmatic mine does not go in to high at all you can move the handle the rod moves going in to the transmission but nothing happens
If the MP clutch pack has to come out for repair then the complete transmission has to come out, as the input shaft comes out the trans rear for clutch pack removal. Might be the shift spool isn't moving, or the MP gear pump is not supplying oil to the spool valve block too..
