MF FE 35 X CLUTCH ASSEMBLY SETTINGS
John Deere D
I shall be replacing a complete Clutch Assembly in the near future...
I have misplaced the settings of the Clutch release fingers...as per pictures.....
Could some one please supply required setting as per picture.........
MF FE 35 Service Manual keeps such setting a secret.....
Thanks
Bob...Owner operator 1963 MF FE 35 X Perkins 3 cylinder Diesel...
The same tool is used for the 35 IF it has the coil spring/Belleville clutch assembly. If tractor has the EARLY two Belleville spring clutch a different lever setting tool is used. Main thing is to have the levers all the same height.
